Old 10-25-2007, 12:03 PM
Tinker51 Tinker51 is offline
Club Cobra Member
Cobra Make, Engine: SPF
Send a message via AIM to Tinker51
I recently changed out a bunch of stuff and had to re-align the pins. Using the Trigo pin tool I was able to get the pins in alignment until I put the final torque on the pin. Then they would "move" every time and I would be unable to get the alignment tool or the wheel on the pins. After a bunch of head scratching I came up with a simple plan. Using the pin tool to determine which way the pin had moved/needed to move I took a dead blow hammer and tapped the pin. I didn't hit them, only tapped them. Worked fine and the wheels mount perfectly.
We have enough youth. What we need is a fountain of common sense
