Make sure you didn't over-tighten any of the pins and slightly mushroom the ends. You only need to screw up one pin (and the mushrooming is really not noticable without a really close look) and there will be no way that rim will mate to the hub. You can lightly grind the circumference of a mushroomed pin at the end, but it's typically not recommended.
-Dean
