Old 10-26-2007, 03:09 PM
Gatorac's Avatar
Gatorac Gatorac is offline
Cobra Make, Engine: BDR 930, 427 Windsor T56
The steering wheel movement is not normal. Does the steering wheel and column move? If so, right behind the dash is a mount for the column. Check to see if that's tight. If the column is not moving and the wheel is, I would suspect a failed bearing in the column itself.
Jim Pomroy
Have Fun!
BDR #930
08 Corvette Coupe
92 Sunburst Yellow Miata
#81 Saturn V Miata Crapcan racer
Panoz GTRA #42
