Tilton and Willwood cylinders look as if they came from the same factory. They can come as kit or bought as individual componets. I beleive the master cylinders come in varyng 1/16" IDs . I'm unsure how smal or how large tey go. I have 3/4"ID brake master cylinders. I went from 7/8"ID to 15/16"ID for the clutch master cylinder, all the same design. I made the change of the clutch master cylinder after encountering a problem. I went and bought a Tilton 1" ID cylinder kit but after concidering all the warnings of over traveling went and bought another Tilton master cylinder kit in 15/16" ID. which I actually usde. A very simple solution for my situation. remember area x travel = volume potential. If you can't increase the travel ,increasing the area increases the effort needed to move the same resistance load. Im sure if you contact the sales departments at these manufactures they wiil connect you with Tech which has allready organized a complete system for your situation.
Mike H
