10-29-2007, 11:31 AM
CA
Cobra Make, Engine: Superformance 351W to 393 Twisted Wedge Heads, Holley double pumper
Originally Posted by Secret Squirrel
SkipB,
I have been trying different tire pressures too. Initially I was told to put 28psi front and 25psi rear. With 28psi in the front, I was getting a lot of steering wheel feedback from the road. I just tried 25psi Front and Rear on a trip to Yuma. It seemed to do real good. I have been having problems with steering wheel shake and I just rebalanced the tires and tightened up the streering rack pre-tension. I have eccentric rings already installed. The trip to yuma was an improvement from previous trips around the Valley. I only have steering wheel feedback on bumpy roads now, otherwise the steering wheel is steady.
Interesting comment re: steering wheel feedback.... because I experience that as well (28psi front) I will reduce air pressure and see if it is reduced...
