Old 11-01-2007, 10:49 AM
RedBarchetta RedBarchetta is offline
Banned
Originally Posted by greg schroeder
The Mickey Thompson ET street drag radial 325/50 15 and 275/60 15 are the exact same height. I put them next to each other off the car and sure enough they're exactly the same height. The middle strip is about 2 inches wider on the larger size, but the rest is identical...
The new narrower tires stick better than my used wider that I replaced. I'll let you know how they work at the strip...It looks like he pulled a 1.5x 60ft and a 10.9x pass at the strip off easy start using a 427 small block.
Let us know how you do! It's probably the narrower tread patch that makes the 275's appear taller.
-Dean
