11-01-2007, 03:09 PM
SC
Cobra Make, Engine: EM 427SC body, chassis, suspension , my design, 427SO, toploader, shaft drive fan,road race pan, Dove heads, Comp. cam,
Lineslinger,
The list price I have seen is $98 each. ( i.e. $200 a set )I am not sure of discounted price.
I will check with Keith Kraft as recommended.
A local engine builder recommended them as well, but I had never seen this particular design.
I had some special issues on one one deck of my S.O. that would cause a FelPro to blow in about 10 minutes running ( not the gasket fault ). But I have run a steel shim gasket for 12 years - no issue.
I am in the process of freshening up the engine ( and I will also correct the block issue ) , and would like to use the best head gaskets. Dave
DB
