Richard,
Are you by chance confusing amps and volts? It sounds like you have an amp gauge(for alt. output), and normally, batteries are tested in volts for charging. It's normal for a battery to put out 13-14 volts under charge, and your amp gauge should show + output. Assuming all this, it would appear all is "normal".
Dave
