engine mounts
hi guys trying to fit boss motor today with existing header pipes, WRONG pull the motor back out, removed pipes,tried again,rear box mount to wide need to be adjusted or modified ,pull it out again,,meanwhile the engine bay is accumilating some nice scratches,, D'OH removed rear mount,,try again ,,all going well lowered engine and box ,,jacked car up so i can get underneath to align engine mounts HOLY SH#T theyre to high and wont fit cant raise engine enough to lower ontop of chassis mounts cause heads want to push through the glass guards ,,,,@#*$%#@! lift it back out ,,,,NICE scratches luckily the engine, once installed will hide most of them ,so take it back out remove mounts and box and try to make sure it fits once i have new mounts YEP she'll do but water pipe need s to be modified if i want bonnet to fit back on, anyway does anyone know which mounts are to be used, ive heard xy/xw????? help,,,,,, please ,,,,,,,someone
thanks darrell
