Just need clarification of the correct pedal for the L76.
When I ordered mine, I had mixed advice as to wether the pedal part number I ordered was the right one - the place I eventually got it from said the same one was used for LS2\L76 etc. It has 8 pins on the connector. The ECU pin out I have for the L76, only shows 6 outputs, plus the pedal connector I ordered in has 6 (in a line) - so do I have the wrong connector or wrong pedal?
The part number I have is 92189345.
Cheers.
