wrench 87 Give me a number to call you at or call me 732-254-3536 after 8:00 est Rick L. I have this cam in my 482 motor with the shelby heads and the erson rocker arm set. I am running studs for the shaft assemblies. I have FI system. The car is going to the dyno shop next week for fine tuning. I am guessing the hp is about 430 rwhp and about 490-500 ft of torque to the rear wheels from 2,500 rpm to 6,200 rpm. I am running beehive springs on my setup without any float yet. The motor is new and limited to 4,500 rpm for breakin. In a 390 you will have a lopey idle and strong midrange power. You will lose anywhere from 20-60 hp from you sidepipes depending on the backpressure they produce.
It is a nice stroker cam Chaplin is running one in his new motor. Waiting for his dyno numbers. Rick L.
