Old 11-03-2007, 06:56 PM
PaulProe's Avatar
PaulProe PaulProe is offline
Cobra Make, Engine: Hurricane - FE
Default Hit on Edelbrocks also
The studs will hit the bottom of the stands on Edelbrock heads also.
I spoke to Erson and they said to grind clearances into the bottom of the stands. I cut some elliptical reliefs, about .200 deep on them.
If you go this way, put the studs in then put the stands on and whack them with a mallet to mark the bottom of the stand. You'll find each stud is in a different location on the stands.
They cut pretty easy with a die grinder and carbide bit. Clean them real good before you use them. You'll have aluminum chips everywhere.
Paul
www.65shlb.com
www.prdcrrct.com
