My continued use of Centerforce
I have a FMS 351W with approx. 425 HP after a little tuning. I had researched RAM and others in my planning to replace my 3550 with a new TKO600. I had just convinced myself not to use a Centerforce PP due to the weights. But I knew I liked my easy clutch pedal. To my surprise after unbolting the existing transmission and bellhousing, I found a FMS PP mafe by Centerforce. I located a new 26 spline CF disk and reused the existing PP.
I did compare the two different performance level RAM pressure plates with my CF PP. I discovered that most PPs are made by one company, I forget the name but that each clutch manufacture differentiates their offering by the design and production of different disks. The PP fingers on my CF were angled shaped versus completely flat that I saw on others. Thinking this design was stronger but more becuase I had expereince with the CF setup, I stayed with CF.
