Thread: Cam Choice?
Old 11-06-2007, 09:13 AM
CarsByCarl CarsByCarl is offline
Originally Posted by Silverback51
Looking for some input on this.
The current engine has a blown headgasket, so as long has I have to pull the engine (it has head studs, not bolts) I'm going to slip in a new 514 crate motor. Anyway, that's the excuse I gave the wife, and I sticking to it unless I can come up with a better one.
The current engine is a 466BB with a Crane Cams 359351 hydraulic roller. Not a bad cam, but I want something with a little more lope to it. Spec's on the Crane cam is .590/.614 lift, 228/238 duration.
The hydraulic flat tappet cam that comes with the 514 seems pretty nice, but I would really like a hydraulic roller. Has anyone replaced there stock cam with a roller a hydraulic roller?
Any input will be appreciated.
Thanks
There's really no performance advantage to a hyd roller and as long as you use the proper oil with the flat tappet it'll actually be more durable than a roller. If you want something with more lope at idle you'd be just as well off going to a different flat tappet cam.
CarsByCarl.com
Ford performance engines
Now on the web! Just click the link above
