It appears Calif is working to close the '1965' out of state title 'loop hole'. While it may work for now, I doubt that will be the case down the road. There is some logic to closing the 'loop hole', as Mr. Morgester noted, 'hot rod' builders will simply move to an accomadting state, register their product as a '1965' or '1932' and thus avoid the Calif smog requirements.
It would seem a better approach would be for the State to simply recognize a way to 'deal with' the 'hot rods' IN State, similiar to what other States have done. Title washing should STILL remain illegal, lowering the real value, illegal. Letting people build hot rods, THATS what the State needs to focus on. 500 SB100 numbers is so low it will only compound the problems.
