  #51 (permalink)
Old 11-08-2007, 06:47 AM
Chaplin's Avatar
Chaplin Chaplin is offline
Cobra Make, Engine: Original ERA 427sc, Powered by Gessford
Hi-Tech-
If you are going to use the car on the street, you should definetely go with a hyd roller instead of a solid roller. Just ask Ernie about the street-life of solid roller lifters.
You won't have any problems with Crane, Comps Cams or Crower. However, to my knowledge, Crane is the only one that makes the hyd roller lifters for FEs. So no matter which cam you get, you will have to use Crane hyd roller lifters.
Replica is not a dirty word.
