Old 11-08-2007, 04:49 PM
wrench87 wrench87 is offline
Cobra Make, Engine: factory five mkIII roadster 445 fe quick fuel 750 q series,irs
Default precision oil pumps rocker assblys
is any one using percision oil pumps rocker assblys?, if so how do you like them . also what do they use for the actual rocker arm?. i heard that the erson use a smaller shaft with needle bearings, and the precision uses a larger shaft with a bushing wich is less likely to break. just tring to decide wich way to go will be using the edelbrock heads.
