Old 11-09-2007, 01:15 PM
Default Not sure on your clutch
wrench 87 If you have a master slave cylinder setup, and have the bell housing on with the throwout bearing on the clutch fork arm, get to 7/16 threaded studs about 4" long and screw them into the top of the bell housing. Slide the trans in to the last inch and lightly press in on the clutch pedal, everything will align and slide in. I do my trans by myself and on an ERA car it works everytime. No force needed. If you have a hydro thrown out bearing on the trans, this will not work and you will have to try and align the input to slide into the pilot bearing or bushing. A lite touch of grease on the input and I polish the end of the input shaft with a dremmel tool and sand roll.You will have to pull the trans into the bell housing evenly. If you use allen head bolts and mark the head and do 1/2 turns on all 4 and keep criss crossing the trans will slide in. Use a small racket and socket so you DON'T break off the trans ears. Rick Lake
