Thread: Doors & Dash
Old 11-10-2007, 06:01 AM
strictlypersonl strictlypersonl is offline
The door pivots on a steel pin that goes through some Oilite bushings in the stationary bracket. It's possible that the pin is loose in the door part (it's secured by set-screws) or the bushings are worn. A (very) little play is normal, so sometimes adjusting the door up to match the latch/catch is all that's necessary.
We can supply an SC dash that will replace your street-style one. It takes the same wiring harness.
