Old 11-11-2007, 04:43 PM
mylesdw mylesdw is offline
Cobra Make, Engine: Ram 427 SC CSX6042. Chev 355. Quad Weber DCNFs
Send a message via ICQ to mylesdw
How about using the standard in-sump pump as the scavenge pump; all it has to do is pick oil up from the sump and push it through the filter; it could run a very weak pressure relief spring since it only has to overcome the filter. Downstream of the filter you feed straight into the pressure section of your dry sump pump (no scavenge needed).
Myles D-W
