Old 11-12-2007, 09:27 AM
CJ428CJ's Avatar
CJ428CJ CJ428CJ is offline
Cobra Make, Engine: ERA #629, BBM Side Oiler Block, 482ci, Richmond 5 speed
If its 428 crank and it's been balanced internally, you should be able to see slugs of heavy metal in the crank counter weights. I think they drill a hole in the counter weight, add a slug of heavy metal and then weld it back up. My crank was externally balanced and it was pretty easy to see where they added the weight.
Chris
