  #25 (permalink)
Old 11-12-2007, 12:33 PM
Default What coil are you running?
Bunkie314 Is it possible that the center contact is burnt off and not worn off? I just replaced my cap and rotor after 5 years. I use all MSD, The HVC coil does do a number on the cap and it has burnt marks into the rotor. Some times you have to run a ballast resistor in some of the ignition systems. This cuts down on the voltage to the coil. MSD tech Should have an answer for you. Grounds are important also for being clean and tight. Rick
