Old 11-13-2007, 04:05 AM
Naumoff's Avatar
Naumoff Naumoff is offline
Cobra Make, Engine: Unique 427 S/C 427 FE S.O. 484 cu in
Originally Posted by ERA713
I have the lakewood bellhousing and I'm using the powermaster starter.I also have the 4.125 scat stroker crank and 66 427 block.had to carve on starter quite a bit for gears to mesh properly.I thought it was the starter.Its working perfectly, just took a little extra work.
I have a similar set up, but a Scat 4.250. Changed from the stock starter to a Powermaster with no problem.
What was it doing to let you know you had a problem?
