Old 11-14-2007, 08:42 AM
priobe's Avatar
priobe priobe is offline
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
Default Superformance & Brakes Please Help !!!!!!
Hello All,
I have been trying to figure out what Master Cylinders are needed for my setup. I am currently using 4 piston Superlite calipers from Wilwood in the front and Dynalite 4 piston for the rear. The master cylinders are Tilton.
I spoke to Tilton and they are recommending the first time 7/8 front and 1 1/8 for the rear. This did not work .... hard pedal but can not lock up brakes.
After speakiing with Wilwood they told me that Superformance is using the same setup calipers and 3/4 front and 7/8 rear.
I know the Superformance vehicles are pre-built but if you have this information or can share how your car stops this would be a big help for me.
Thank you
Caliper 4 pistion Superlite piston size 1.76
Caliper Dynalite rear 1.38 piston size
