there is more room under my 4 post lift than the two post lift i have . even when at the same identical lift height . the wheels hanging down protrude into the outer areas of the car roof underneath if a conventional car , thus more restrictive . the cars i can park under my 4 poster in some cases will not park under the 2 poster because of those dangling wheels above . i had a set of wheels for my 4 poster and never used em , gave them away to someone else with the same lift as mine . my 4 poster is my preferred lift , easier to use , quicker to use / set car on it etc . if ya need to change wheels etc i have a jacking tray for the 4 poster that slides fore and aft between the two ramps . a bottle jack and then jack stands on the jacking tray and voila, no problem. if you do alot of wheel changing then the 2 poster is better . bill.
