Originally Posted by 65cobra1
The space between the frame and the filter is too small for any of my band wrenches or any of my cup wrenches.
I can get it on hand tight but I need a wrench for that 1/2 turn to finish the job.
I'm using a Motorcraft FL-1HP filter.
Do you just get a smaller i.e. shorter (Read possibly less efficient) filter or is there a special tool you use?
I appreciate the help,
Ivan
I had a simillar problem with my
oil filter... older model SPN with a huge filter, couldnt remove it as the frame rail was in the way... longer bolts with 5/8 spacer moved the filter toward the engine just enough to remove it...
