Thread: 351W Tuning
Old 11-15-2007, 09:58 AM
RRCOBRA RRCOBRA is offline
Your high speed air bleed is small for a street setup. Most street setups are around 190-210. Weber tuning guides usually say that a good starting point is 40 larger than the mains. Also you need to check to see what size exhaust pump valve you have in the bottom of the fuel bowl. Sound like the carbs are stock settings from the factory.
Lou
