Merv, you will be able to fit any headlight into your existing buckets.
Those buckets you have will be the same in operation to our plastic buckets.
I'll put up some instructions on our web site on how to fit/remove headlights from these buckets. I'll post here when they are done.
Originally Posted by David Hodgson
DRB (not sure about DRB 2000) and D-Type Cobras need to use the Mini rims. Same headlight opening but larger diameter on the base. Both will fit same bucket.
David, the DRB 2000 still has the same front guard shape, so you can still use the larger chrome rims.
You can also fit the smaller chrome rims on DRB's. They end up being slightly smaller than the front guard, but actually look alright. Just depends on the look you are going for.
