Thread: Engine quit
Old 11-17-2007, 08:18 AM
turnpike boy turnpike boy is offline
Cobra Make, Engine: Unique 427SC/331/5 forward
Originally Posted by double ugly
He used a drill to get the instant 100 lbs of pressure. The plugs were out and the starter should have given it plenty of RPM shouldn't it. I thought a method of pre-oiling was to pull the plugs and spin the engine until oil pressure is indicated. It has a Pertronics with a MSD Blaster coil.
Thanks, John
Yes, on all accounts. Pre-lubing is done exactly that way - use a drill and spin the pump. The distributor, however, gets turned by the camshaft and - in turn - spins the pump. Cranking the motor is more than fast enough to build pressure; you might have to crank it for a hair longer than you would normally do, but you will see pressure build.
If the dist drive gear pin is busted, you're not gonna build pressure because as soon as the pump starts pumping, the effort required to move that oil will far exceed the level of friction the busted pin will generate between the dist shaft and the gear.
You HAVE popped the dist out to have an overall look at it, right?
