Old 11-18-2007, 10:25 AM
Michael C Henry Michael C Henry is offline
Cobra Make, Engine: Everett Morrision FE 427 so 2-4s
You are talking About a 5/16" bolt or stud. . If you take full advantage of the depth of the original hole, drill it out and tap it corectly and straight for the Heli-Coil. It will take more than the load needed to hold and seal your surge tank. The ARP SS carbruetor stud Have a rounded ball end for starting the nut. You can slide the surge tank over the studs with gasket applied, and everything will stay inline.
Mike H
