Originally Posted by gtc
but I think only CR does GM engines (is that correct?)
Gday Graham - im pretty sure Brian at Homebush can and will adapt his chassis to any engine you like. If he can fit one of the modern ford boss motors in, a smaller lightweight LS series engine will be no probolem.
Best suggestion I can offer is get out to one of the NSW meeting monthly and check out as many as you can. Thats the only way you can get an appreciation of the differences between the kits. And go with a list of the specific things you want to check out, otherwise youll be heading home with stars in your eyes not knowing any more then before you got there!
Cheers.
