Old 11-18-2007, 04:17 PM
Rickd Rickd is offline
I had a Unique FIA with a stock 302 HO motor that ran really well. The intake on that car is an Edelbrock Performer RPM with a Holley 600 double pumper carb. Runs great. Modified the motor adding Trick Flow aluminum heads and a little more aggressive cam - same intake and carb - and runs extremely well. New FIA car almost done (an ERA), and the motor is a 302 stroked to 331, AFR aluminum heads, and an Edelbrock Performer RPM Air Gap intake with a Quick Fuel carb. Check out the crate engine builders like Keith Craft and see what they are using on their small block motors. They build a ton of them and they run well. Good luck and have fun. Rick.
