HI HVSREDSLED,
The engine is a 4 bolt Dart Iron eagle "302" block with the 4 1/8 inch bore.
The crank is an eagle stroker giving the engine a 369ci capacity.
Forged rods, CP pistions custom ported Dart Pro 1 heads.
Solid roller cam. 1.6 crane rockers.
DC@O 50mm 8 throttle body manifold, 1 3/4 primaries stepped up to 2 inch then in a 4 inch pipe with a 2 1/2 inch perforated tube.
The fuel system is overkill and the engine breath thru the bonnet scoop.
Motec M48 runs the engine and an MSD 6A ingnition for spark.
The static compression is 11.5 to one but some of that is bleed off by the cam.
There is actually not one Ford made part in the engine
I am using V power (shell) but may switch to BP Ulimate.
Phil
