Thread: Sway Bars
Old 11-23-2007, 07:17 AM
Jimv455 Jimv455 is offline
Cobra Make, Engine: A&C, Stroked 408, TKO 600
Thanks, guys. RBLong, I checked out you links it looks very nice and super heavy duty, but it does seem to hang pretty low. Have you even had any problems with ground clearance?
What I was thinking was something more like Roscoe's. It doesn't look anyone makes a setup which will just bolt on without some fabrication. Roscoe I like those brackets that bolt on to the sway bar mounts. Did you fabricate them or does someone make them? Pending that it sounds like my best bet is take some measurements and then call Heidt's see what they have that's close and use that as a starting point..
Ok now for my really interesting question. The stock setup on the A&C uses strut rods to handle the braking loads place on the control arm, instead of A shaped lower control arm.. Has anyone ever toyed with idea of gettting rid of the strut arms, and instead use the sway bar bolted directly to the lower control arm to handle the braking loads? Trust me I know you would need a really heavy duty arm and wouldn't gain me much other than 10 lbs of wieght and a cleaner look.
Thanks,
Jim
