Thread: Tranny Line
Old 11-24-2007, 11:35 AM
65cobra1's Avatar
65cobra1 65cobra1 is offline
Cobra Make, Engine: SPF #2450, Roush 342RE
Default Tranny Line
There's a line running from the back of the tranny (TKO 600) that goes forward then up.
It looks like it runs into the dash area. I am assuming that this is either for oil pressure or oil temp.
It is attached to the back of the tranny by a small bracket secured with a 3/8 bolt.
In checking over the car after a run yesterday, I noticed a small amount of seepage traced back to the top of the line that is resulting in drops accumulating at the bottom of that line.
I tightened the 3/8 bolt a few turns and could have kept going except I was concerned that I would bend the small bracket assembly.
The end of the line that attaches to the tranny bracket has a piece of metal crimping. Either crimping is bad or the bracket needed some tightening.
I'll keep watching but until then...
My questions are:
1...What is this line?
2...How tight can this bracket be secured?
3...If I have to replace the line is there anything I should know to prevent a disaster?
Thanks for your input,
Ivan
Forget the health food...I need all the preservatives I can get !!!
