Old 11-25-2007, 12:55 AM
hookedonford's Avatar
hookedonford hookedonford is offline
Default have same problem
Olddog,
I have Mallory 4305 regulator with Mass Flo setup and have the same problem. I actually should notify Mallory because this is the second unit with the issue. It is bleeding off through the top and threaded pressure setting rod. I put a little thread sealer on the rod and nut and adjusted to 39-40PSI. Good luck, Jim
