Thread: hey jmarsey
Old 11-25-2007, 08:17 AM
vector1 vector1 is offline
Cobra Make, Engine: jbl
Default hey jmarsey
i understand you are running your car at the minimum ride height. how is that working on the street?
what are you using for track rims and tires. compmotives are nice but with tires they weigh 47# each. i'm going to need another set if the $$$ holds out.
ref. your clutch/tranny. i'm looking at the 53 series tilton setup which requires tranny w/chevy bolt pattern and input shaft. did you use the chevy tranny or ford? also, i believe you had to shorten your input shaft?
i've mocked up the dry sump pump and it fit nicely with some milling on the bracket. i'd post pics if i could figure out how.
