Old 11-25-2007, 05:11 PM
priobe's Avatar
priobe priobe is offline
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
dlampe / 68gt500,
I have tried many different config to the carbs and yeild the same results
Here is config # 1
42 choke
120 idle holder
65 mains
210 air corrector
f-11 / F-16 / F-7 Etube
180 main
oo bleed
When you look at the LM1 everything looks great but all of a sudden you spikes that go to 22 on the LM (in and out / up and down like a mis fire
Next setup
60 holder
60 jet
f-7 / f-11 /f-16
210 air corrector
180 main
42 choke
Same result
I know most people with the webers run:
37 choke
60 idle
120 holder
F-7 e tube
210 corrector
160 main
50 bleed
My car ran pig rich.
Hmmm maybe I should try the 37 chokes again to see if the problem still exist.
I would love to send my data log to someone to see if that come up with the same results.
Any thoughts??????????????/
Standard setup other wise
Holley pump
msd dist
6al msd
return line
I am actually using the heavy springs in the dist to see if that would help
When I gradually easy into the throttle it is fine but drive normal and it happens.
