  #32 (permalink)
Old 11-26-2007, 12:32 PM
Power Surge's Avatar
Power Surge Power Surge is offline
Originally Posted by mickmate
Larry looks good BTW. Hey a dumb dash switch question. Fuel was an on/off or a two position? Does it switch between two pumps for a main/reserve or a valve between them?
Fuel was a single switch. The engine runs off the mechanical pump, then when you run out of gas, you flip the switch to the electrics for the reserve. You would also want to use the electrics for racing as they have a higher capacity than the mechanical.
Sal Mennella
