Imagine2frolic, I can't picture what you are suggesting. If we shim the right motor mount, it will raise the passenger side, oppposite of what we want. What would be needed is a motor mount that is thinner, or a lower engine perch, or as cobrajeff did, enlarge the cutout.
Chaplin, I'm sure he has them on the correct side, the primaries are dramatically different in length from left to right. You couldn't get them to mate the side pipes at all if they were swapped.
Kramer, I don't hold much hope that new pipes will cure this .. unless you are going to have the primaries custom bent
Now that might be worth checking into with a local exhaust shop.
I still think I'm gonna put a limiting bolt throught that right mount, mirror image of the left one. Just waiting for my motor to get back from Keith so I can do a trial fit.
Sam
