Having a hard time locating a pilot bearing for a 427 FE (most parts stores only carry the bushing). Does anyone have a part # for the bearing type?
Originally Posted by Carnut427
The only time the bearing/bushing does anything besides keep the front of the trans shaft in line is when you have your foot on the clutch. Otherwise the front trans shaft and crankshaft are turning at the same speed. I personally see little difference between the two, but I use the bearing.
Dan
