Old 12-01-2007, 02:02 AM
Ross Smith's Avatar
Ross Smith Ross Smith is offline
Cobra Make, Engine: RMC 302 Windsor Supra 5 speed Jag Suspension
Hi Slowy,
I have a 5L Windsor in my RMC and it cuts out too! My car will run fine and then cut out at idle when it is hot. It also has a habit of refusing to start after it has had a run and then been off for a few miunutes. It will always restart in a couple of minutes after the bonnet has been up. I an sure that my problem is heat related as I have a single in-tank pump amd I can hear the fuel circulating when I try to start it. I am still trying to find the problem, so any suggestions would be welcome. I am running an Autronic SM4 ECU and my engine has coil packs.
Ross
