Old 12-01-2007, 06:08 AM
patrickt patrickt is offline
Originally Posted by SantaFe66
Do the new Edelbrock heads have the modifications mentioned in the 09/2004 post from Luke-44?
I believe all Edelbrock heads require a little bit of work to allow the oil to drain back a little faster. It really isn't much work to do and doesn't require overly specialized tools.
I will be using a set of Harland Sharp roller rockers on the heads and would also like to know if I need to restrict oil flow to the rockers with that mod as well.
HS is high quality stuff -- and yes, I would restrict the flow to the top. But remember, the most important part of your oiling system is your oil pan. If you run an OEM pan with a HV pump on your build you're risking the life of your engine. Here's a nice shot of the HS setup.
