Old 12-01-2007, 10:58 AM
CHANMADD's Avatar
CHANMADD CHANMADD is offline
I am sure that you guys are recirculating the fuel ..ie..return line. Check the pressure regulator ,I would agree that sounds the most logical.The factory regulator.. (Is this the one you are using) ..requires vacuum to operate ..Right? Maybe with the hot cams etc the regulator is not working properly at hot idle???
