I have had this happen a couple of times - in my case, one of the selector rods was interfering with another resulting in two gears being selected at the same time.
Try moving the selectors on each shaft into neutral position and then select a gear and see if it works. There does need to be some clearance there.
Puzzling that it happened after you were moving - that is a new one on me.
