Old 12-01-2007, 03:54 PM
RedEsprit RedEsprit is offline
Cobra Make, Engine: ERA 742 / 428 FE
All forward gears, cluster gear and the reverse idler turn when I start the car in neutral with the clutch engaged. Fine. The slider gear for reverse is flush against the reverse idler. Fine. Select any gear and the main shaft will not turn...just kills the engine. Its like the main shaft is absolutely locked in place.
