Old 12-03-2007, 05:49 AM
blykins blykins is offline
I've never ran a mechanical fuel pump on an engine that I've built for myself. Just leave the eccentric off...most cams come with two dowel pins. One is longer than the other. Just use the appropriate pin and go with it. The cam bolt washer works just fine without the eccentric.
If you need an eccentric, check Ebay.
