Originally Posted by Kramer
Yes, at the end of day..here is where I am at:
1) the engine (427SO) is centered and level in the car
2) the mounts are correctly installed.
...I also put a little square meeting piece of metal inside the pedalstal with a single hole to keep the engine from moving too much left to right (my own version of a torque strap.
3) the cutout hole in the passenger side is smaller than the drivers side.
...I can fit a finger in the top of the whole on the drivers side, but maybe just a finger tip (think like 1/4 inch clearance) on the passenger side.
4) after talking to Doug for a while at ERA, I have concluded that as I get close to finishing the car, I will use a bur and open up both holes (on the top side) by 1/2 inch to make more room). Then once I am completed finished, I will have folks at the body shop fix any little scratches from my building process and clean up the holes).
PS...the car is running now...and its sounds nasty (in a good way). Someone said it sounds like you violently woke up a giant and they are right. I will fire it again after I get some work done to to the interior and will youtube it. Can't wait until next summer!!!
Glad to hear you've got that baby running...I would've had mine running this weekend except for a brake line leak and some very cold weather keepin' me out of the garage. If it warms up around here, I'll be have it running this weekend. I too have very little clearance between the pass. side sidepipes and the body and will probably have to open up the hole a little. Good luck.
