ERA chas- the comment that you are referencing is in regards to where the side pipe brackets line up with the frame back near the rear tires. To fix this, I loosen everything up and got them both withing about an inch of the straps on both sides. Then tighten everything up and push them in while someone else slide the bolts through.
