HELP!! Need input on problem
Guys,
I've got 600 near-perfect miles on my Everett- Morrison and started having problems yesterday. I'm running a 460 Super Cobrajet with a MSD 6AL, Performance distributor and Inferno coil. Carb is a 750 Mighty Demon. The engine quit running three times during slow speed and once at 60 mph. It's as if the ignition stops providing spark and the engine dies. All gauges and fans continue to operate normally. Once stopped, the engine cranks right back up seconds after cutting off as if nothing happened. There is no consistent trend when the failure occurs and no warning signs. I've tried to duplicate the problem while the engine is idling by checking the harnesses to no avail. Pulled plugs and they're perfect and the engine is performing normally. I'm leaning toward a bad coil but would like to hear your input.
Thanks
Greg
